Hard Drive not Found
edited December 2016 in Help
I am trying to install Kerio Control ISO is located http://download.kerio.com/dwn/kerio-control-installer.iso
Its a Firewall, I am not able to install that in VULTR, I can install this without any issue in my own virtual environment but every time I run the ISO in Vultr I get error message it says Hard Drive Not found, Its a little strange, I will appreciate any help.
  • It looks like some of Kerio's products can be installed via a package manager if you are using linux. Might want to try that.
  • how can install via package manager?
    can you explain more?
  • edited December 2019
    use any iso editor then edit the file ks.cfg
    From
    #ignoredisk --only-use=sda
    To
    ignoredisk --drives=sdb,sdc,vda1,sda,vda
    then save again the .ISO and upload it using https://transfer.sh
    Use URL to add ISO to VULTR
    after that attach or create new server using added ISO from VULTR
    Go to web console, finish the installation wizard.
    it will work
