Help transferring wordpress from digital ocean to vultr
Can someone here give a newbie guide to transfer a wordpress site from digital ocean to vultr
Thank you !
  • What is your DO setup like (cores, ram, disk) aka what requirements do you need?
    Once you know that the simplest thing to do deploy a new instance using the prebuilt application type and select WordPress.
    Next you need to setup the firewall to allow your ports (80,443).
    Then you should be able to get into the wordpress installation and copy in your data and/or recreate your config.
